Results 1 to 7 of 7
  1. #1
    Join Date
    Sep 2009
    Location
    brisbane, queensland, australia
    Posts
    3
    Default "Hi, I am from Australia an
    "Hi,
    I am from Australia and have just bought a Haines Hunter C1900 with an i/o Merc 470 with the serial no. 5786369.
    I can't determine how many h/p is this engine.
    I have looked high and low but no luck.
    Also, I wish to replace this...what motor and leg would just drop in?
    Any good suppliers?"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "It's a 4 cyl. w/170 hp.
    "It's a 4 cyl. w/170 hp. No equivalent engine package will just drop in its place. Another 4 cylinder 135 hp. will fit. You will want to make sure the boat transom, floor and stringers are not rotted before spending another dime.
    Your cheapest route to go would be to have the engine rebuilt w/an external alternator and 4" heat exchanger and the OD serviced. The 470 engine is a real strong power plant for its size.
    The other route to take would be to install a 4.3L EFI V-6 220 hp engine and a new SEI OD. Some modifications to the engine mounts would have to be made. The engine cost in U.S. dollars would be about $5,800 and the OD cost is $1,200."
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    Default "If your motor has a 4 bbl car
    "If your motor has a 4 bbl carb it is 190 hp, if it has a 2 bbl carb then it is 160-170hp."
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
  4. #4
    Join Date
    Sep 2009
    Location
    Posts
    3
    Default "thanks Guy for the info. a
    and KGhost, will find out whether it is 2bbl or 4
    regards
    anyway
    aziz"
  5. #5
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "Abdul: These two are both
    "Abdul:
    These two are both good suppliers; find out what your import duty will be before buying; it may be cheaper to rebuild a used engine where you live.
    http://www.ebasicpower.com/
    http://michiganmotorz.com/"
  6. #6
    Join Date
    Aug 2009
    Location
    Sydney, NSW, Australia
    Posts
    211
    Default "Abdul Australia has a free t
    "Abdul
    Australia has a free trade agreement with the US, which makes small purchases from the US a breeze. If importing from US, you have a $1000 AUD limit (inc shipping), before duty and sales tax kick in. If you go one cent over $1000 AUD, Aust sales taxes will apply to the full amount. try to keep your purchases from US to below $1000 AUD, or split your purchases, if extra costs of shipping are OK.
    I think this is modeled this way to suit the hobbiest rather than commercial business. I make plenty of small purchases from US dealers using the US Postal Service with no problems so far, usually save up to 50%. Its more trouble than walking into your local dealer, But if you are organised and can wait 2 weeks for your parts to arrive, you can save a bunch of money.
    As for a new power plant for the 19 haines, Id stick with what youve got. all other alternatives are V6 or V8, which would use up too much beam in that boat. The 470 is a good unit for a boat that small. BTW, the 470 is a ford V8 with half the cylinders cut off. The weakest link in that donk is the Stator, Get external alternator as Guy suggested.
    There are kits out of melbourne for marinised commodore V6s', dont know anyone whos done it and would be a lot of work. Still be a bit to wide for that boat. TM."
  7. #7
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    902
    Default "Not that things couldn't
    "Not that things couldn't have been swapped out over the years but generally as the label reads, 470 = ~170 hp w/ 2 bbl and 488 = ~180-190 w/ 4 bbl. Only the head is from Ford the block is an aluminum block Mercruiser bastardized creation.
    If you're dropping in a whole new engine and leg you could do anything you want as long as it matches up. 4.3L V-6 will have more parts available and should bolt up to your leg no problem as long as you have room for a wider engine."
Similar Threads
  1. Replies: 11
    Last Post: 02-13-2011, 05:13 AM
  2. AQ130 B20 Hands down thee worst engine ever engine from hell
    By samscrappyboat in forum Volvo Penta Gas Archive
    Last Post: 07-31-2009, 06:29 PM
  3. Warm engine no idle engine lags with quick throttle advance
    By cbass149 in forum Mercruiser Sterndrive Archive
    Last Post: 04-29-2009, 04:59 PM
  4. Small amount of water entered engine Compartment and now engine wont start
    By artaudio in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-29-2008, 08:54 AM
  5. Replies: 3
    Last Post: 05-27-2003, 10:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
