mercurymark
"150 black max has been sittin
"150 black max has been sitting up for a few months now but have been running it every month or so and has been starting nicely but i now cant trim it up from the very bottom position, it just goes click if i go either way. Tried fully charging the battery but no use. I want to get to the power trim motor to check connections but it is all obstructed by the engine now. How can i manually get it back up, considered removing the fluid screw on the side to relieve the hydraulic pressure but noticed the warning sign about high pressure in down position. Any advice gratefully recieved. Also if the boat is to be laid up for a period is it a bad idea leaving it down or should it be tilted right up and rested on the stay.
Thanks in advance."
Thanks in advance."
