1985 85 hp force prop question
cyclesico
having a hard time locating on
having a hard time locating one 13x19 pitch.. 15 spline . will any with same dimentions work /years /makes thanks brian
"Good luck with that. I was tr
"Good luck with that. I was trying to get another prop as well recently. The best I could find was $260.00.
I ended up buying a composition prop so I'd have a spare but I liked it so well, I use it as my primary prop and keep my aluminum as the spare. Many people don't like the compostion props but honestly, at least in my case, it outperforms my aluminum prop in all areas exept hole shot. My top end is considerably faster and it's a much smoother prop. A 4 blade prop and it only cost about $90.00. It's at least worth a look.
Check them out."
