Results 1 to 15 of 15
  1. #1
    Join Date
    Aug 2009
    Location
    Los Banos, Ca, USA
    Posts
    7
    Default "I have a 120 hp 4L mercruiser
    "I have a 120 hp 4L mercruiser 4cyl engine (1968?). I need tune up specs, ie; plugs, points, timing and carb idle settings, (rochester 2bbl). Anyone?"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,395
    Default "SN: 3825578 and below uses A
    "SN: 3825578 and below uses AC CR44N, gapped at 0.035", point gap is 0.022" and dwell is 28-34 degrees, timing is 6 degrees BTDC.
    SN: 3825578 and above uses AC MR43T plugs, gapped at 0.035", point gap is 0.022" and dwell is 28-34 degrees, timing is 6 degrees BTDC."
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,395
    Default idle for the first one is 500-
    idle for the first one is 500-600 RPMs
    idle for the second one is 650-700 RPMs
  4. #4
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    897
    Default You should probably invest in
    You should probably invest in a Mercruiser manual if you're going to work on it yourself.
  5. #5
    Join Date
    Aug 2009
    Location
    Los Banos, Ca, USA
    Posts
    7
    Default "Thanks a lot, PugetSounder. I
    "Thanks a lot, PugetSounder. I didn't make the connection, Mr. Obvious. I have an income of less than $1100.00/mo. I spend $350/month on medical insurance and try to do some fishing when I can afford the bait and gas! Just maybe, if you have an extra manual lying around, you could send it to me. Oh, by the way, in California I have to pay about $42.00 a year for my license, so if you want, you could send me some cash too!"
  6. #6
    Join Date
    Aug 2009
    Location
    Los Banos, Ca, USA
    Posts
    7
    Default "Guy, Thank You for the info,
    "Guy, Thank You for the info, now my son has something to work with since this boat out dates him by 30 years and he has never work on an engine 'without smog'. I found the needle valve set screw adjustments in an old Rochester carburetor manual."
  7. #7
    Join Date
    Aug 2009
    Location
    Los Banos, Ca, USA
    Posts
    7
    Default "To everyone in general, if yo
    "To everyone in general, if your not part of the solution, your part of the problem!"
  8. #8
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default You have a son...and you are t
    You have a son...and you are teaching him all you know
    that warms my heart
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
  9. #9
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    897
    Default "You have a son...and you
    "You have a son...and you are teaching him all you know that warms my heart"
    Too bad it's mostly his attitude.
  10. #10
    Join Date
    Aug 2009
    Location
    Los Banos, Ca, USA
    Posts
    7
  11. #11
    Join Date
    Aug 2009
    Location
    Los Banos, Ca, USA
    Posts
    7
    Default "Hy_Stat, He's a pretty go
    "Hy_Stat, He's a pretty good 'shade tree mechanic' he is in the US Army as an equipment maintainence Tech E-6. He could teach me more than I could teach him."
  12. #12
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    897
    Default "No problem Ronald apology acc
    "No problem Ronald apology accepted.
    I'm not saying boating should be a rich man's sport but as we all know here it is an expense and can be expensive. Trust me, my boat is 27 years old and whenever I see people on the lake with a brand new version of mine that cost them anywhere from $30K -$40K I think how foolish. But to each his own, I can't afford that much so I bought a good used one with the plan to do my own work.
    Buying a $25-$30 manual and having a bit of mechanical experience can be the least expensive way of owning and having fun in a boat. We all have them. Good luck."
  13. #13
    Join Date
    Aug 2009
    Location
    Los Banos, Ca, USA
    Posts
    7
    Default Wiser words were never spoken!
    Wiser words were never spoken! Can you tell me where I might find some place with an assortment of manuals for the older boats? Mine is a 1968 Silver Liner 17' Rambler
  14. #14
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,395
    Default Try eBay motors
    Try eBay motors
  15. #15
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    897
    Default Amazon.com is a good place for
    Amazon.com is a good place for used manuals too. Also if you have any used book stores I've found various manuals there and for cheap.
    Found these:
    http://www.amazon.com/gp/offer-listi...043&sr=1-3
Similar Threads
  1. 200 ocean pro tune up specs
    By saltlife321 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-12-2009, 12:48 PM
  2. Tune up specs
    By agitator in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 06-05-2009, 08:31 PM
  3. 1988 OMC Tune Up Specs and oil level in outdrive
    By mcfall in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-28-2008, 12:38 PM
  4. Tune up specs for 440 Chysler
    By cayman_seaskiff in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 05-01-2007, 10:06 AM
  5. 69 Chrysler 440300 HP Tune Specs Needed
    By arabian in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 09-05-2003, 12:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
