1995 70 HP Lower Unit
daveh
"I just started leaking lower
"I just started leaking lower unit oil, and it looks like there's water in it. Should I start with the outermost seal and see what happens, or go farther into the lower unit?"
"Need To Drain Oil, And Then P
"Need To Drain Oil, And Then Presure Check L/U To See Where is Leaking And Replace The Seal or Just Total Reseal The L/U But You Still Needs to Hold 15 lbs
Good Luck Frankie
[email protected]"
