"I have a 1996 30 HP M30-A3 th
"I have a 1996 30 HP M30-A3 that has a dead zone about half throttle. Any throttle before that spot before or after is just fine. Engine cranks easy without much choking and idles smooth with out any hessation until about mid throttle. Checked and changed spark plugs and have swapped between two new set just to make sure of firing. I have pulled and cleaned the carb throughly three times, I only found just a small flake of trash(black pepper sized)the first cleaning and nothing the other two times. I removed both jets and sprayed and cleaned with air and carb cleaner. I made sure that all the tiny holes were clean and open, I could see light thru each of them. I have cleaned my fuel tank and air dryed it also. I also replaced the hose bulb and pumped clean gas out of the hose before connecting it to engine, I also pumped clean gas out thru the fuel pump before connecting the fuel line to carb. I even carried it to my dealer for cleaning before I started my own cleaning. The fuel pump is pumping fuel when the engine is running. Any ideas what would cause my problem?
Jimmy K"
Jimmy K"
