Unknown year of 75 hp montgomery ward sea king and it wont start
efranck2
"i have a 7.5 montgomery ward
"i have a 7.5 montgomery ward sea king, it wont start. and i need to know the year, any info will help ;) here are the numbers
K750 3107 D
992124
60 52207 R"
well i just rebuit it and have
well i just rebuit it and have it running a little bit. dose anyone know how many turns the jet screws need to be loostened for it to run the best?
If you can get it started- you
If you can get it started- you should adjust the bottom main jet pointing out of the bottom of the carb. If it's not there -you have a fixed jet. Idle starts at 3/4 and adjust after warm the main can begin at 1/2 and open up throttle setting till it wants to die then go back to the main jet and open up till it will run at full throttle. Remember all the fuel runs thru the main jet first then the idle fuel is taken from there and runs the idle.
