250 76 deg stroke V6 carb
"Motor had lean miss at idle a
"Motor had lean miss at idle and just off idle. Some one damaged idle pilot screw and carb so I Replaced #2 carb with new superceeded unit. Now when started it wants to take off run wild. I did go through sync & link after installing carb. Checked tps for ohm . They were low if I am right 64-1030 book said alot hihger. I dont have the proper harness to hook up to my digital voltmeter to set tps proper. Also, New carb has a hose from bottom of bowl up to upper part of carb. Why the change ? Boat has been in my care too long, need input to get it done, Thanks Geno"
