"My ideal engine/drive combo &
"My ideal engine/drive combo (in staying with the AQ series) would be one of the roller cam/follower SBC's with either the DP C or SP C drives (looks very much like the 290 drive).
The DP C1 would be my choice.
Ratios will be 1.95:1 and 1.61:1 respectively.
This drive eliminates the reverse latch, eliminates the SS cylinder swing bracket, has a great cylinder system, offers NO Gimbal system, easy bellows replacement, uses an all steel drive coupler, no routine engine alignment after initial install, No thru hub exhaust and will still fit your existing AQ series transom cut out (may require slight modification).
The AQ 260 Flywheel Cover can use the fine spline PDS and will accommodate the transmission drive shaft fwd yoke.
The AQ 260 style exhaust mans/risers will work with the "C" Y pipe, etc.
IMO, it does not get much better than this drive!
