"OK guys, I have seen this exa
"OK guys, I have seen this exact problem posted on this site and others, but there never seems to be a definitive answer. I'm going to copy and paste the description of my problem from a post on another site. This guys problem was never resolved either. Here we go...
"I have a 1999 Johnson 150 that is giving me trouble. When I first launch the boat and crank it, it idles fine, planes off fine, and runs pretty good. Then, when I shut the engine off and say, fish for an hour, then crank it up, that’s when the problems start. It cranks, but has a rough idle. When you put it in gear, it stalls out. I have to keep it in neutral and slowly rev it up to high rpm for a few seconds in order to try to plane it off. Sometimes this rev up and put it in gear process goes on several times and it’s getting worse and worse. If I can quickly give it full hard throttle and get it on plane, it runs fine then until you shut it off for a length of time and then the whole process starts over. The odd part is the first time it’s cranked for the day, it does fine. The problems start after it’s been run and then is shut off for an hour or so. This is very frustrating. Does anyone have any ideas what’s going on? Thanks."
I will also give you some background on what I have done to my engine lately. The stator was replaced last year, and a coil pack was replaced last month. Compression is good on all cylinders.
Thanks in advance guys. I've got to believe there are others out there researching this same problem due to the number of posts I have found on the subject."
