Results 1 to 2 of 2
Thread: OMC 225 Upgrade
  1. #1
    Join Date
    Aug 2009
    Location
    San Diego, CA,
    Posts
    18
    Default "I have a 1974 OMC 225 (Ch
    "I have a 1974 OMC 225 (Chevy 307). I'd like to get more power out of it and looking for options. The engine is newly rebuilt, so not inclinded to replace whole engine (although what are my options?, i.e. coupling bolt pattern restriction). Anyone have experience with an Edelbrock or Holly marine head?"
  2. #2
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default "Marine head? You mean cylinde
    "Marine head? You mean cylinder heads?
    Not going to do anything for you. The stock cylinder heads on a 307 will breathe fine at boat engine rpm's.
    Coupling bolt pattern is the same on any Chevrolet V8 (283, 305, 307, 327, 350) made up to about 1987.
    The new Chevrolet crate engines made in Mexico also continue to use the pre-1987 bolt patern.
    A GM Crate 350/290HP would be your cheapest power upgrade. It makes 260HP in a boat.
    Too bad you rebuilt the 307, but if you could demonstrate it before pulling from the boat, you could probably sell it easily enough.
    Then, to use the additional power you would have to change the propeller to a higher pitch , or...you may need different outdrive gearing. Depends what pitch you have now. "
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
Similar Threads
  1. Possible to Buy a new EMM to upgrade 50 to 60 hp
    By groenling in forum Johnson Evinrude Outboard Archive
    Last Post: 02-22-2009, 02:05 PM
  2. Upgrade from 30 to 50
    By quipa in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-10-2008, 03:52 PM
  3. 5 HP upgrade
    By seabrook in forum Nissan Tohatsu Outboard Archive
    Last Post: 06-05-2008, 12:41 PM
  4. HEI UPGRADE
    By cbdinak in forum Volvo Penta Gas Archive
    Last Post: 07-21-2007, 12:10 AM
  5. OMC 283 upgrade
    By kbflyboy in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-24-2007, 12:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
