Click for Volvo Penta parts and manuals!
Results 1 to 5 of 5
Thread: Runs rough
  1. #1
    Join Date
    Aug 2009
    Location
    metropolis, il, us
    Posts
    5
    Default "I have 1994 crownline with 5.
    "I have 1994 crownline with 5.0 volvo penta [ford]. This boat sat for about 3 years. It runs rough and would not idle very well. When you gas on it in the water, all it wants to do is backfire. I put new fuel pump,map sensor, throtle pos switch. Iam lost at this point. Can someone help???????????"
  2. #2
    Join Date
    Jul 2009
    Location
    BARKING, ESSEX, UK
    Posts
    40
    Default "hi there had the same thing o
    "hi there had the same thing on my boat i got about a 1 month ago it has the aq130c in it and it turned out the air filters needed cleaning, and the contacts on the coil pack was dirty wear it had sat for so long, am new to this site may be sum thing eles but this may help!"
  3. #3
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,646
    Default "If a boat of mine sat for 3 y
    "If a boat of mine sat for 3 years and ran poorly I'd start with..
    new plugs, dist cap and rotor.
    dump all old fuel put fresh fuel in and add "seafoam" or your favorite cleaner."
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  4. #4
    Join Date
    Aug 2009
    Location
    metropolis, il, us
    Posts
    5
    Default "Thanks for the help! I will t
    "Thanks for the help! I will try all of those,and get back to you guys later. Hope it works."
  5. #5
    Join Date
    Aug 2009
    Location
    metropolis, il, us
    Posts
    5
    Default "I have got one more ? That fi
    "I have got one more ? That filter, going to the map sensor, is that just a regular fuel filter?"
Similar Threads
  1. At wits end still runs rough
    By jeff6898 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-26-2008, 10:34 PM
  2. 120 OMC runs rough
    By gordo in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-22-2008, 02:25 AM
  3. AQ120B Runs Rough
    By jjlutzel in forum Volvo Penta Gas Archive
    Last Post: 09-01-2007, 03:56 PM
  4. 200 john runs rough
    By mdhunter in forum Johnson Evinrude Outboard Archive
    Last Post: 07-28-2007, 09:27 PM
  5. 23L runs rough
    By afansler in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-11-2006, 12:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
