MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 12 of 12
  1. #1
    Default Here's my problem I start
    Here's my problem I start up the engine it runs smooth in idle. I put it in gear and everything is fine while going slow. When I try to go 2/3rd throttle it just won't open up runs at half speed. After about 10 minutes of trying to get the engine to open up it starts to stall out and it's very hard to start. Sometimes I have to wait 15-20 minutes to start it up but will run very ruff and stalls out. Most times when I start it up I have to shift it quickly into gear in order for it to go. When I slow it down almost to a crawl it will stall. I recently had a water separator installed. What could be the problem? Any suggestion? Thanks in advance!!!
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,325
    Default Classic fuel starvation. You&
    Classic fuel starvation. You'll need to find out why:
    1. Vent on tank blocked
    2. Air leak in fuel line before the pump
    3. Bad fuel pump
    4. Carbs need a rebuild.
    Jeff
  3. #3
    Join Date
    Apr 2008
    Location
    Johannesburg, Gauteng, South Africa
    Posts
    367
    Default Old juice? Can cause poor resp
    Old juice? Can cause poor response due to octane being lost as a result of storage.
  4. #4
    Default "BJ, the tank was pumped out w
    "BJ, the tank was pumped out when the fuel separator was installed. All new fuel in the tank.
    FG, I checked 1 & 2 they are fine I will have to get someone to check 3 & 4.
    I want to add something new. I can start up the engine easily in neutral when the prop is out of the water when I lower the prop in the water it stalls out right away. Do you still think it's the fuel pump or carb?
    Thanks in advance!!!}"
  5. #5
    Default mercury has a 2 stage stator.
    mercury has a 2 stage stator. have your stator replaced with a mercury one not aftermarket.I found out the hard way after 4 mechanics and 2300 dollars.when the 2nd stage of the stator burns out the boat more or less goes into limp mode so you can get to shore.You need a repair place that has a large enough dunk tank to check stator output at wide open throttle
  6. #6
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    Default I would still bet on the fuel
    I would still bet on the fuel problem (pump or carbs) - running fine without a "load" means it's getting enough gas at that point - once the motor is stressed a bit it's gaggin' looking for more fuel than it's getting...
    If it ran totally fine below about 2500 rpms I would bet on Tracey's comments....
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  7. #7
    Default "Hey Stan, how'd it go??"
  8. #8
    Default It ended up being a bad fuel p
    It ended up being a bad fuel pump. Hopefully I can get through the season without anymore problem.
  9. #9
    Join Date
    Apr 2008
    Location
    Posts
    367
    Default Happy boating! Nothing wors
    Happy boating!
    Nothing worse than a bad experience on the water when the weather is great and the mood foul...
  10. #10
    Join Date
    Sep 2003
    Location
    Posts
    15,325
    Default Tell me about it! Had my gran
    Tell me about it! Had my grandkids at the boat last weekend and the motor wouldn't run--bad spark box (or etc.) Poor kids were sure disappointed.
    Jeff
  11. #11
    Join Date
    Apr 2008
    Location
    Posts
    367
    Default "Jeff, Imagine convincing
    "Jeff,
    Imagine convincing the grand kids to row the tub with an experienced Tech on deck!
    You should post a new thread, we'll help you solve the issue..."
  12. #12
    Join Date
    Sep 2003
    Location
    Posts
    15,325
    Default "Might just take you up on tha
    "Might just take you up on that, Ben. The charging coil is reading open, so I hope that's it.
    Jeff"
Similar Threads
  1. 2005 mercury 25 hp 2 stroke problems
    By jcp in forum Mercury Mariner Outboard Forum
    Last Post: 11-24-2016, 04:11 PM
  2. 2005 50hp 2 stroke
    By sparkiew in forum Mercury Mariner Outboard Archive
    Last Post: 08-28-2009, 11:39 AM
  3. 2005 50hp Mercury Outboard Ignition Swtich Wiring
    By uk8181r in forum Mercury Mariner Outboard Archive
    Last Post: 07-07-2006, 05:33 AM
  4. Problems wb98 50hp Mercury Boat Motor 4 stroke
    By judi in forum Mercury Mariner Outboard Archive
    Last Post: 06-22-2006, 07:28 AM
  5. 2005 Mercury 50hp elpto rough idle
    By IDIOT in forum Mercury Mariner Outboard Archive
    Last Post: 01-20-2006, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
