"I just had a problem with the
"I just had a problem with the impeller shaft on my 125B. After overheating I was checking to see what happened and found no water coming into the strainer. figured another impeller. On taking it apart I saw that the shaft had come right thruogh the bronze pump cover, pulling out from the cross member. I had an old pump and put that cap on. It ran at 180 degrees fine. any idea what caused this."
