"I was given a 1987 8HP motor
"I was given a 1987 8HP motor for my dinghy. Model: CE8RCUD S/N: B1399186. It hasn't been used in years. I want to replace the plugs, impeller, and rebuild the carb because it has been sitting for so long. Plugs & impeller no problem. But the carb has me stopped. One nut, port side, is obsured by the rewind starter coil. How do you get the carb off? Can you remove the rewinder without the spring going for a walk?"
