"HI, on cold start run's g
"HI, on cold start run's great, when warmed up and sitting, hard to start will idle sometimes but when you give throttle boggs down and stall's for acouple of times (without hitting primer, worse when hitting) could this be a bad sensor I don't hear the alarm going off, or maybe some type of other way not to run motor, its a 1993 johnson 200hp oceanrunner"
