Click for Crusader parts and manuals!
Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2009
    Location
    Miami, FL, USA
    Posts
    4
    Default "Hello, I replaced the two
    "Hello,
    I replaced the two elbows on one of my engines after I got water in two cycinders. The engine ran fine for 3 hours, but yesterday, after running for one hour, the RPMs stateded going up and Down (crusing at 3100 RPMs) for about 3 minutes and then it eran fine. Any suggestions?"
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,252
    Default Crud in the tank? Shared ta
    Crud in the tank?
    Shared tanks or dedicated tanks?
    Did you pull the manifolds off to change the elbows?
  3. #3
    Join Date
    Jul 2009
    Location
    Miami, FL, USA
    Posts
    4
    Default "Thanks, Dedicated tank. I
    "Thanks,
    Dedicated tank. I did not pull the manifolds as the mechanic told me that is was not needed (fresh water and sea water cooled). I was thinking of checking the fuel filters later today?"
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,252
    Default "Changing the filters wouldn&#
    "Changing the filters wouldn't hurt.
    You can also check the vent line to the tank - make sure it is kink free, no low spots, and the fitting outside of the ull is clean. some styles are preferred for mud wasps and the like."
  5. #5
    Join Date
    Jul 2009
    Location
    Miami, FL, USA
    Posts
    4
    Default "Hi makomark, I drained the
    "Hi makomark,
    I drained the gas filter yesterday (the gas was a bit yellow not clear). I ran the boat and it ran well. Hopefully stays this way.
    Thanks for your help.
    MM"
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,594
    Default "That yellow crap was a water/
    "That yellow crap was a water/ ethanol solution that does not like to burn. keep changing those separators, and you'd better add some conditioner (like Star Tron).
    Jeff"
  7. #7
    Join Date
    Jul 2009
    Location
    Miami, FL, USA
    Posts
    4
    Default "Jeff, Thanks. Do you reco
    "Jeff,
    Thanks. Do you recommend changing the filters or can I get away with just draining the gas out of the filter casing?
    MM"
  8. #8
    Join Date
    Sep 2003
    Location
    Posts
    15,594
    Default Do both! Jeff
    Do both!
    Jeff
Similar Threads
  1. 150 hp force after 5min goes from 5k rpms to 0 rpms
    By war_cloud in forum Chrysler Force Outboard Forum
    Last Post: 01-20-2009, 05:51 PM
  2. Rpms
    By mguili1947 in forum Volvo Penta Gas Archive
    Last Post: 08-09-2008, 07:10 PM
  3. RPMs
    By J T B in forum Johnson Evinrude Outboard Archive
    Last Post: 07-06-2008, 05:06 PM
  4. Replies: 6
    Last Post: 06-13-2008, 10:39 AM
  5. Not getting rpms
    By tlcwrx in forum Mercruiser Sterndrive Archive
    Last Post: 07-19-2007, 12:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
