Click for Crusader parts and manuals!
Results 1 to 6 of 6
  1. #1
    Default Twin 86 454's FWC. The stb
    Twin 86 454's FWC. The stbd Holly carb has oil hanging on the bottom of the flame arrestor. Is it possible that the vacum is sucking it from the hoses that are connected from valve covers??? (Each valve cover has a hose leading to a "T" then leads to the flame arrestor.) Port engine bone dry with same set up. Could I be having a Carb problem with excessive vacum? Any thing over 2200 rpms and the engine flutters after running for about an hour which I assume is related. Any solutions on this? I am looking forward to the day when I can open the fridge more than the engine hatches.
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,557
    Default Sounds like excessive blow by.
    Sounds like excessive blow by. I suggest a compression test.
    Jeff
  3. #3
    Join Date
    Aug 2008
    Location
    Fairport, NY
    Posts
    1,670
    Default "A couple of things come to mi
    "A couple of things come to mind on this issue. Yes, very likely related to blowby, and not related to excess vacuum.
    I don't understand the "T" comment. You should have one, 5/8" hose from each valve cover and they EACH go to the outside of the flame arrestor.
    Internally, the valve cover area is subject to oil misting, and a significant blowby will tend to blow out oil. You can move to a breather cap with the internal mesh to catch the oil mist. This will help even with strong blowby. They can be had either "twist in" or "push on" styles. About 3" in diameter or so, and with a grommet and barb to accept the 5/8" hose."
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,181
    Default An 86 with a Holley....sounds
    An 86 with a Holley....sounds like a mod.
    Are the rocker covers stock or aftermarket?
  5. #5
    Default Diver Dave...On my "T"
    Diver Dave...On my "T" comment; I have a breather tube from each valve cover (stock covers btw)that lead to a three way tube in the shape of the letter "T". Since the flame arrestor only has one breather tube fitting...I used that connection so that B-tubes can connect to the flame arrestor. The old style flame arrestors had two attachements (one for each cover) the new ones do not. (2-yr old Hollys) So the opinion is excessive blowby...and a compression test will confirm this?
  6. #6
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,181
    Default If the baffles are still in th
    If the baffles are still in the covers then blowby is a good candidate. Do the compression test dry & wet.
Similar Threads
  1. Where to buy this model Holly carb
    By uniflite in forum Crusader Marine Engine Forum
    Last Post: 09-12-2009, 01:45 PM
  2. Holly carb
    Last Post: 09-04-2009, 08:54 AM
  3. Holly Carb
    By atbears in forum Miscellaneous marine engine topics
    Last Post: 09-01-2009, 09:34 PM
  4. 1987 PCM 351 Holly 4150
    By romans116 in forum Pleasurecraft Marine PCM Forum
    Last Post: 06-23-2008, 08:56 AM
  5. OMC GM 305 Holly Carburetor problems
    By otto in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-04-2006, 01:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
