Click for Crusader parts and manuals!
Results 1 to 3 of 3
  1. #1
    Default "I have a 454xl in my 96 Carve
    "I have a 454xl in my 96 Carver that is starving for fuel. I have checked the pickups in the tank, changed all filters, and swapped carbs from starbord to port. By the way the port engine runs great and the fuel tank is common. I suspect the fuel pump (electric). Any thought or similar problems."
  2. #2
    Join Date
    Jul 2009
    Location
    wood ridge, nj, usa
    Posts
    3
    Default change the fuel pump
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,305
    Default "Could be the pump - a pressur
    "Could be the pump - a pressure tester is a lot cheaper than a new pump. Anti-syphon valve(s) installed at the tank pickup? they have been known to go whacky and cause all kinds of issues. sounds simple but check the shutoff valve to make sure its fully open. Could be an air leak in the fuel line, too....loose clamp or fitting not tight.
    You can also check the voltage at the pump...a corroded connector can cause a voltage drop and make the pump unhappy."
Similar Threads
  1. fuel pump issue 1997 5.7
    By makojim in forum Mercruiser Sterndrive Forum
    Last Post: 06-03-2010, 08:33 PM
  2. Fuel Issue
    By jnscherr in forum Johnson Evinrude Outboard Archive
    Last Post: 08-19-2009, 10:33 PM
  3. Now that I got that fuel issue out of the way
    By bobbyj202 in forum Mercruiser Sterndrive Archive
    Last Post: 07-05-2009, 11:04 PM
  4. 454XL fuel pump
    By kevin_z in forum Crusader Marine Archive
    Last Post: 02-26-2009, 02:41 PM
  5. Fuel Issue
    By jshane37 in forum Johnson Evinrude Outboard Archive
    Last Post: 11-25-2008, 08:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
