Click for Volvo Penta parts and manuals!
Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2009
    Location
    rockland, ontario, canada
    Posts
    3
    Default "1988 volvo penta 4 cyl , 16 v
    "1988 volvo penta 4 cyl , 16 valve,,,the timing belt blew causing major damage to 8 valves. had 0 compression to all 4 cyl. we Rebuilt the top end ,valves, gaskets, new timing belt put it all together started first shot went for a 45 minute ride and the belt blew. Im lost what on earth caused it to snap everything looked great someone help just lost tonnes of money??????"
  2. #2
    Join Date
    Feb 2006
    Location
    Ladysmith, BC, Canada
    Posts
    5,862
    Default "I would start by checking the
    "I would start by checking the condition of all the timing gears (they should not be pitted), timing gear guides, and the belt tensioner."
    [URL]http://www.grandmaraismichigan.com/Recreation/fisherman.gif[/URL]
  3. #3
    kingfishy's Avatar
    kingfishy Guest
    Default "Steve, I picked up my Volv
    "Steve,
    I picked up my Volvo boat at the marina from a customer that blew a timing belt, caused all kinds of damage,valve and piston mine is an AQ151B.
    That's what Volvo's are famous for, blowing timing belts that wreak havoc, and cause damage.
    I love my Volvo, but that's just what happens as the belts wear."
  4. #4
    Join Date
    Feb 2006
    Location
    Posts
    5,862
    Default "Actually, damage should only
    "Actually, damage should only occur in interference head engines like the AQ171. All other OHC models are non-interference, and a broken timing belt should not make the pistons hit the valves (at least, in theory)."
  5. #5
    kingfishy's Avatar
    kingfishy Guest
    Default "El, Theory is great on pap
    "El,
    Theory is great on paper,but the man said his timing belt blew causing valve damage.
    It's a common occurrence on Volvo. I've seen it often. Nothing to argue about, your experience with them may differ."
  6. #6
    Join Date
    Jul 2006
    Location
    Qualicum Beach, BC, Canada
    Posts
    341
    Default "This is from a UK Volvo car f
    "This is from a UK Volvo car forum:
    "here is the truth.
    Its the head and pistons that are of concern here.
    most b230e/et/f/ft engines are fitted with 530 or 531 heads, these are all non interference.
    some b230e and all b230k (carb) engines have the 631 (heron) head, these are interference.
    all 16 valve engines are interference.
    To be sure what head you have, look on the side of the head above the exhaust manifold, the cast number is there."
    http://www.volvoforums.org.uk/showth...t=16+valve
    FWIW"
  7. #7
    Join Date
    Jul 2006
    Location
    Posts
    341
    Default "Another bit of Info Good m
    Good morning,
    The casting is stamped on the side of the block in the cars. However the b230f engines are not an interference motor even though they are sometimes listed as such.
    Thanks,
    Paul
    Chapman Motors [[email protected]]
    However, Paul has a bunch of B230's for sale [img][/img]"
  8. #8
    Join Date
    Feb 2006
    Location
    Posts
    5,862
    Default "Thank you, Tom. I have recomm
    "Thank you, Tom. I have recommended Chapman before in this forum, because I have found them very helpful and knowledgeable in the past, and they used to have a HUGE amount of Volvo B21, B23 & B230 OHC engines and engine parts (new and used) in stock. If I was considering marinizing a car engine, they would be on top of my list if I wanted to get a decent engine (albeit they are not the cheapest)."
Similar Threads
  1. Need help Replacing a timing belt on a volvo penta bb140a
    By Invisionconstruction in forum Volvo Penta Gas Engine Forum
    Last Post: 07-16-2010, 12:07 AM
  2. 1988 volvo penta 4 cyl 16 valve dual carb
    By sclermon in forum Volvo Penta Gas Archive
    Last Post: 08-04-2009, 11:10 PM
  3. AQ 145B timing belt and shattered valve shim now what
    By bertie in forum Volvo Penta Gas Archive
    Last Post: 08-03-2009, 11:53 PM
  4. Timing belt set up volvo penta diesel TAMD22
    By mariatomkinsonrocketmailcom in forum Volvo Penta Diesel
    Last Post: 04-16-2009, 10:08 AM
  5. 115 honda timing belt replacement amp valve adj
    By bigcat in forum Honda Outboard Archive
    Last Post: 02-26-2009, 10:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
