Click for Volvo Penta parts and manuals!
Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2009
    Location
    Orlando, FL, USA
    Posts
    2
    Default "Thought I had a bad switch, r
    "Thought I had a bad switch, replaced it with a new one and have the same problem where the engine will not turn off at the switch off position. Any thoughts, or has anyone experienced this same problem?"
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default Check the resistor at the alte
    Check the resistor at the alternator.
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,259
    Default "Ooops, glitch here... double
    "Ooops, glitch here... double post. "
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,259
    Default "Been there/done that for a fe
    "Been there/done that for a few customers.
    The ignition sources the alternator field circuit via this OEM part. When this fails, the alternator is free to now back-feed your ignition so the engine will not shut down with the key switch.
    If you were to get it to shut down, the field then lets go of this circuit.... all appears to be back to normal.
    While it says resistor on it, and if memory serves me, I think this is actually a diode. You can make one with parts from Radio Shack, or order a new OEM.
    Portland, Oregon
  5. #5
    Join Date
    Jun 2009
    Location
    Kuah, Langkawi, Kedah, Malaysia
    Posts
    4
    Default Same thing happened to me on M
    Same thing happened to me on MD22-P Volvo Penta and was simply the cut-off electrical wire to the fuel pump had come off. When reconnected it worked fine.
Similar Threads
  1. 97 Mariner 90 ignition wonbt turn off
    By joubear in forum Mercury Mariner Outboard Archive
    Last Post: 01-06-2009, 05:22 PM
  2. Replies: 2
    Last Post: 07-19-2008, 01:41 AM
  3. 3 Beeps when I turn ignition on
    By gkm24 in forum Mercruiser Sterndrive Archive
    Last Post: 06-10-2008, 09:05 PM
  4. Engine will not kill at ignition switch
    By Jeff Garris in forum Archive 2003-2007
    Last Post: 07-05-2006, 04:57 PM
  5. 1978 evinrude 140 turn off switch half motor still runs
    By Buddy Green in forum Johnson Evinrude Outboard Archive
    Last Post: 09-25-2003, 05:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
