"Can anyone tell me how to remove the lower unit gear housing on this motor I have removed the prop, the face plate exposing the gears, the "C" clip from the bottom of the drive shaft and the single bolt holding the gear housing but the housing does not seem to want to slide off easily is there some thing that I'm missing? I have done some research and the motor in question has the water inlet holes on the lower left side of the lower unit as well as the holes down the front of the lower unit. I have read that that would suggest that it is about a 1950 or later model and that the lower unit should remove with out havng to take the power head off I hope this is the case.
I want to inspect the impeler however it does pump water but I noticed it oosing a bit of milky water out of one of the little drain holes on the gear housing when I removed the prop and cover there seems to be no lube in there at all but both gears seem to be a good shape.
Should I just grease it and bolt it back togeter or is there any other seals that need to be replaced to stop leaking?
any help would be great!!!!
THANKS"
