"I need some help with a issue
"I need some help with a issue with this engine.It is a intermitent problem of loss of RPM, does not go below 4200. Will drop from 4600 or 5000 to 4200. Some things I have done
Ran on seperate tank
Changed the VST filter
Have water seperator, always clean
Have done fuel pump diaphrams.
Changed plugs
Ran ring free through system
Checked compression all 110
Checked fuel pump pressure 35psi.
Ran new fuel line
new primer bulb.
New fuel filter
Checked CDI for code with winky blinky,none found
Is there any way to check coil. could this be a coil breaking down.
What about a injector and how do you check
Please help"
Changed plugs
Ran new fuel line
new primer bulb.
New fuel filter
Please help"
