57 Volvo Penta Throttle linkage needs adjustment
cragonese
MY port engine throttle is ver
MY port engine throttle is very tight. Both engines were like this from the day I bought it. Stbd engine is too loose. I cant figure out how to adjust the friction lock if there is one for either engine. Any ideas?
I cant find a way to access it
I cant find a way to access it. Doesnt look like there are any screws holding the box in place. Is it clipped on? A screw diver to pop it off? I dont want to break it. Your refering to the box at the base of the Throttles?
"That's where it should be
"That's where it should be. Unfortunately, there are many models and I have no clue which one you are using. Some of them (Yamaha) have a screw on the outside that you can use to do the adjustment. If what you have in your boat is original equipment, perhaps a call to the boat manufacturer would do the trick?"
