Click for Crusader parts and manuals!
Results 1 to 6 of 6
Thread: Damper Plates
  1. #1
    Default "I've lost 5 or 6 transmis
    "I've lost 5 or 6 transmissions over the last 4 years, which appear to have been caused by damper plate failure. I've got a 40' Cruisers with two Crusaders HO 475 hp engines and BW transmissions. My mechanic doesn't know what's causing the damper plates to blow. Any ideas."
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,556
    Default Rough idling and/ or high neut
    Rough idling and/ or high neutral idle speed.
    Jeff
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,174
    Default "which BW gear? Engines rea
    "which BW gear?
    Engines really rated at 475HP?
    Agree with Jeff, high idle speed will beat them up quick. High RPM engagement will do it too."
  4. #4
    Default "Thanks for your replies. The
    "Thanks for your replies. The engines both run smoothly and don't idle high. I've been real careful about high rpm engagement and that hasn't happened.
    My engines are the 8.1 HO's. I've got 5000 series BW transmissions. For the first few failure I was using the 862975A2 damper plate which is what Mercruiser says is to be used for the 5000 series. Crusaders paper manual said the same thing, but after several failures (in which the housing was punctured) my mechanic called Crusaders and they said the paper manual was wrong and that their internet manual was correct and said that the 860125T damper plate should be used. Although my mechanic thought that plate was only to be used with a 72c trans, he put two in. I got a few hours before one of them failed, although it didn't blow the housing or destroy the transmission. We don't know what to do at this point.
    Again, any ideas would be most appreciated."
  5. #5
    Join Date
    Sep 2003
    Location
    Posts
    15,556
    Default I'd get on the phone with
    I'd get on the phone with Crusader and not hang up 'til they resolved the problem.
    Jeff
  6. #6
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,174
    Default "Don't know the details bu
    "Don't know the details but can tell you Crusader doesn't 'package' those 5000 gears with anything anymore.....Maybe its the gears taking out the damper plates and not the other way around.
    I like Jeff's approach but think it will take more than one call to resolve this one. I'm thinking after 4(+) years, you may not get much, if any, help.
    I'd start looking for some ZF or HURTH gears..."
Similar Threads
  1. Crusader 350ci choke plates
    By Wayne Newman in forum Crusader Marine Engine Forum
    Last Post: 05-27-2010, 12:28 PM
  2. Drive Plates for 220 Crusaders
    By bob_on_this in forum Crusader Marine Engine Forum
    Last Post: 08-20-2009, 03:03 PM
  3. KAD 43 DP Oil leaking from Inspection plates and PCV Valve
    By maxsuds in forum Volvo Penta Diesel
    Last Post: 08-14-2009, 03:54 AM
  4. Engine name plates
    By tdspurrier in forum Johnson Evinrude Outboard Archive
    Last Post: 09-14-2006, 09:35 AM
  5. Stabilizer plates hydrofoils do they work
    By shawn in forum Outboard motors archive 2000-2004
    Last Post: 03-15-2002, 04:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
