"1977 280 outdrive
1) O
"1977 280 outdrive
1) On page 114 #37 (link is below)In the calculation for measuring for shims, a clearance dimension of 0.24mm calculated. A shim thickness of 0.24mm is recommended, allowing for a remaining play of 0.04mm. Shouldn't the shim thickness be 0.20mm, leaving 0.04mm clearance?
http://www.thestraycat.net/files/Volvo%20Penta%20Workshop%20Manual.pdf
2) Preparing to measure for shims between the lower and mid sections, shouldn't the bearing race easily drop in place in the recess in the lower unit? Mine does not. The fit is very tight.
3) The bolts holding down the tilt mechanism (30 years old) on my 280 drive are rusted into place and corroded. I am thinking of grinding away the base of the tilt mechanism (yes I need a replacement, Ricardo) allowing a maximum amount of bolt remaining to attempt removal. Any problems torching in this area? Any other suggestions? PB Blaster will be used as well. If I shear of those bolts I will have a MAJOR problem.
Jay}"
1) O
"1977 280 outdrive
Jay}"
