searcyfarms
"Hello, Thanks in advance to a
"Hello, Thanks in advance to all of you for whatever comments or advice you may offer. I am attempting to fix my broken boat. My father in law bought the boat new in 1984. It has a 488 mercruiser on it.
I have diagnosed the problem to be in the lower unit and have removed it and found a replacement. The fella that sold me the lower unit said it is not a TRUE Alpha drive even though it has the Alpha case since it was produced in 1984 and it also has a preload pin on the tip of the gear that inserts into the upper part of the outdrive.
So my question, how do I get this thing apart to replace the parts inside? The gears on the tip of the upper shaft are twisted and the gears/bearings in mine seem to be out in some manner. It is clickin and making noise like a rough bearning, not to mention the grey/silver looking oil from all the ground up metal inside. The man that sold me the lower unit assembly said I will need some kind of special tools. Is that accurate? No one around here will work on my unit since it is over 20 years old they tell me.
I have no idea how to work on one but I did get it removed and grew up on the farm working on everything under the sun so I guess it cannot be too much different than a combine, tractor or anything else. Bearings, gears, shims, spacers, shafts, bushings etc....
THanks again,
Robert"
THanks again,
Robert"
