"El:
I did a few of that '
"El:
I did a few of that 'set-up's', but for a special reason. It was all on 'super fast' rigs, and the intention was to give the props a 'spin-off' at start. You have a parallel in the relief holes in the raker props. I'm not able to see if the props at the pick have the same holes, but I suspect no.
Running stb = counter clock and port = clock wise on a 280/290 SP set-up have never been a success. However if You have an extreme deep V, above 25' it might be a solution, but that again may depend on props used. For a std set up and installation, I would go the conventional way. The toe-in factor is sometimes the most difficult one, and any play in drive suspension and steering systems might mess it up a bit."
