Click for Crusader parts and manuals!
Results 1 to 5 of 5
    Default "Hi, I have a FWC 2004 6.0
    "Hi,
    I have a FWC 2004 6.0 MPI that has a slight leak on gasket between exhaust elbow and exhaust manifold.
    I need to replace gasket.
    1. Should I use thin coating Mercruiser Perfect Seal on gasket surfaces prior to installation?
    2. What is the torque recommendation on the 4 bolts?
    3. Does coolant need to be drained prior to removing elbow?
    Mark"
    Sep 2008
    Maryland - USA
    7,174
    Default "1 - won't hurt anything
    2 - 25 ft*#
    3 - good idea to drain the manifold.
    make sure both gasket surfaces are clean, true (flat), and dry before reassembly."
    Sep 2003
    New Tripoli, PA, USA!
    15,556
    Default "I'm gonna sound like a br
    "I'm gonna sound like a broken record... Torque wrenches are worse than nothing useless the threads--male and female--are spotlessly clean and properly lubricated.
    In other words, throw the torque wrench away and use common sense: Tighten it down 'til it feels nice and tight, then add a flat or two. Ran the motor 'til it's fully warmed up, then add another flat or two.
    More joints end up leaking and blowing the gasket out due to good torque wrenche use than anything else! Trust me this, I've been at it over 50 years.
    Jeff"
    Default "Jeff, What's a flat?"
    Sep 2003
    15,556
    Default One sixth of a turn. Hex nuts
    One sixth of a turn. Hex nuts have 6 flats.
    Jeff
  1. exhaust elbow
    By emuman in forum Volvo Penta Gas Engine Forum
    Last Post: 03-27-2010, 06:41 PM
  2. Exhaust Elbow on 8kwg
    By northern_lights in forum Universal and Westerbeke
    Last Post: 08-02-2009, 11:36 PM
  3. Hot exhaust elbow
    By rcaponeg in forum Mercruiser Sterndrive Archive
    Last Post: 06-03-2007, 10:14 PM
  4. 19831995 Chrysler 440 exhaust manifold exhaust elbow
    By cassifree in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 05-07-2006, 07:04 PM
  5. Need exhaust elbow
    By Candy Hendrix in forum Archive 2002-2006
    Last Post: 10-30-2001, 09:37 AM
