Electric fuel pump
43_lx_merc_1996
"Looking to replace my current
"Looking to replace my current electric fuel pumps for my AQ260 350. Not sure which one to get as the originals have no part numbers etc.
My choices are:
WALBRO 7 PSI PUMP 43gph
WALBRO 3 PSI PUMP 43gph
WALBRO 4.5-7.0 PSI PUMP 23gph
Any suggestions appreciated!
Thanks,"
"Sierra part 18-7281 is the di
"Sierra part 18-7281 is the direct replacement for your original pump.
http://www.marineengine.com/newparts/part_details.php?pnum=SIE18-7281&returntopa ge=sierra_marine/sierra00811.htm
Also, you can buy the expensive version from Volvo Penta (part 14).
http://www.volvopentastore.com/FUEL_SYSTEM/dm/cart_id.571712635--session_id.5390 06856--store_id.366--view_id.325123
However, both are mechanical fuel pumps (not electric). Not sure why you have electric fuel pumps installed, as the AQ260 came originally with mechanical fuel pumps. But if you want to go electric, the 7 psi is probably your best choice, as the original specification calls for 6-8 psi."
