Click for Crusader parts and manuals!
Results 1 to 3 of 3
  1. #1
    Join Date
    Feb 2008
    Location
    Salem, OR, USA
    Posts
    2
    Default "As some of you may know, find
    "As some of you may know, finding parts for the 165 hp 229 V6 Crusader can be a challenge. After smoking an exhaust hose last week, it is finally time to replace the risers and elbows. When Looking for the risers and elbows I only see the one listed for the V8 that look very similar with a 3" outlet. Does anyone know if these risers and elbows will work for the V6 as well.
    Thanks."
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,840
    Default "Most of the 'older' 3
    "Most of the 'older' 3" outlet elbows interchange across all engines with the 'log style' manifolds.
    If you have a specific part number, best to call MFG's tech support department and confirm before you order."
  3. #3
    Default I too have an older 229ci. Tho
    I too have an older 229ci. Those 3" elbows for the small block chevy worked fine when I swapped mine. Several years later I had to replace the manifolds as well and there are no log style options available anymore for that engine so I went with OSCO center rise manifolds/elbows.
Similar Threads
  1. Exhaust riser
    By boat34 in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 01-03-2014, 07:25 AM
  2. Exhaust riser temps
    By mike1970 in forum Mercruiser Sterndrive Archive
    Last Post: 08-22-2008, 08:40 PM
  3. Exhaust Riser Question
    By mainship35 in forum Crusader Marine Archive
    Last Post: 01-30-2008, 07:53 PM
  4. Exhaust Riser question
    By timaddington in forum Mercruiser Sterndrive Archive
    Last Post: 10-13-2007, 08:08 AM
  5. Exhaust Manifold and Riser Question
    By lee42lee in forum Volvo Penta Gas Archive
    Last Post: 04-13-2007, 03:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
