Click for Crusader parts and manuals!
Results 1 to 6 of 6
  1. #1
    Join Date
    Jun 2009
    Location
    Posts
    70
    Default anyone know the correct plugs
    anyone know the correct plugs for a 1985 350 crusader? and has anyone switched over the point/condenser distributers to the electronic conversions with any luck?
  2. #2
    Join Date
    Aug 2008
    Location
    Fairport, NY
    Posts
    1,528
    Default "AC/Delco MR43T; .035 gap, un
    "AC/Delco MR43T; .035 gap, unless the ignition system is high energy, then you can go to .045 or so. Who made the distributor?"
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,104
    Default "I prefer the NGK's - BPR6
    "I prefer the NGK's - BPR6FS.
    Several have done the conversion and several have gone with full electronic replacements - use the search button at the top of the page for more details.
    I prefer the full electronic distributors. Replacing the points with a firctionless pickup is good but it doesn't eliminate the corrosion issues with the advance weights, springs, and posts. The ocean salt environment was my biggest factor."
  4. #4
    Join Date
    May 2006
    Location
    Posts
    170
    Default MR 43T I believe is the consen
    MR 43T I believe is the consensus I believe particularly for higher hour motors.
  5. #5
    Join Date
    Sep 2007
    Location
    Egg Harbor, New Jersey, USA
    Posts
    1,574
    Default I have used both... I am curre
    I have used both... I am currently using the MR43's with a .045 gap and the BIGGEST reason for that is that I bought a box of 50 NOS plugs last year....I have had no trouble with either ONCE MY OTHER PROBLEMS WERE DEALT WITH
  6. #6
    Join Date
    Jul 2007
    Location
    Sarasota, Florida, USA
    Posts
    37
    Default I use AC/Delco MR43T with .035
    I use AC/Delco MR43T with .035 gap. I get them at NAPA cheaper than other places I've been to.
Similar Threads
  1. 1987 crusader 454 ac to ngk plugs
    By cruisers00 in forum Crusader Marine Engine Forum
    Last Post: 11-29-2009, 05:49 PM
  2. Marine spark plugs vs normal spark plugs
    By bgallan in forum Johnson Evinrude Outboard Archive
    Last Post: 06-20-2009, 01:07 AM
  3. Spark plugs for Crusader
    By jpilot in forum Crusader Marine Archive
    Last Post: 04-01-2008, 06:02 PM
  4. 351 Crusader 1979%3d Spark plugs
    By billharvey in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 07-13-2007, 05:26 PM
  5. Crusader Spark Plugs
    By Corry from Texas in forum Crusader Marine Archive
    Last Post: 01-04-2006, 05:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
