DF70 oil inside cowling coming from breather
1wirenut
DF70 has crankcase oil leaking
DF70 has crankcase oil leaking heavily into cowling and oozing down motor.seems to be coming out of breather cover. engine runs like a sewing machine. no smoke in exhaust. engine oil is clean. please help!!! thanks
Hi i was hoping you could resp
Hi i was hoping you could respond with an answer to your question. I'm having the same problem. Mine started after changing my oil. Thanks Allan.
"Allan, I had a hole in the o
"Allan, I had a hole in the oil filter believe it or not. Sounds like you may just have a bad seal. Good luck to you."
