prestonstark
"boat has run perfect, then on
"boat has run perfect, then one AM hard to start- idles rough, real bad hesitation between idle and 1000 rpm- above that- perfect. Recently changed plugs, plug wires, fuel filter, cap, rotor..... problem started awhile after this maintenance. -Even put in another set of plugs. However, total of 300 hrs- carb has never been touched. Only problem is below 1000 rpm?????"
