Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2009
    Location
    Posts
    72
    Default "My Friends case... Ran fine
    "My Friends case...
    Ran fine was sitting for about a year,Changed fuel in tank...when I went to start it would start but then choke itself out.
    It will run but it don't want to Idle. And when you put it in gear it will die.
    Compression on number 3 cylinder is at 80 and the rest are at 110.
    Can this happen from just sitting?
    Any thoughts how to troubleshoot would be great.
    Thanks Mike"
  2. #2
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "yep,it can,...what,is the mod
    "yep,it can,...what,is the model number?"
  3. #3
    Join Date
    Jun 2009
    Location
    Posts
    72
    Default "Model number E75DPLSOR Notice
    "Model number E75DPLSOR Noticed the top plug was real clean ( Like new) compared to the others
    ITs been sitting a while,also the primer bulb was not getting hard,assuming fuel pump is bad."
Similar Threads
  1. wont stay running 1988 5.7 305
    By jamie_bradley22 in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-28-2010, 06:11 AM
  2. 1976 40hp Evinrude wont stay running
    By 62SeaKing in forum Johnson Evinrude Outboard Forum
    Last Post: 06-22-2010, 12:56 AM
  3. Etec 2005 75hp running rough
    By ratmower in forum Johnson Evinrude Outboard Forum
    Last Post: 06-18-2010, 06:14 AM
  4. 78 Evinrude outboard 15 hp wont stay running
    By tunaonfire in forum Johnson Evinrude Outboard Archive
    Last Post: 11-07-2009, 10:24 PM
  5. Wont stay running
    By mike wendel in forum Johnson Evinrude Outboard Archive
    Last Post: 05-27-2006, 07:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
