Click for Crusader parts and manuals!
Results 1 to 3 of 3
  1. #1
    Join Date
    Feb 2007
    Location
    Posts
    224
    Default "Hi Guys, i have a 315hp carb
    "Hi Guys,
    i have a 315hp carbed Crusader with a Mallory electronic ign. Sometimes it has no spark and refuses to start. Other times it's ok,I repl the ballast and ignition coil along with the upgraded ignition module in the dist.I've wiggle tested the wiring harness while running and it's ok.Voltages and grnds to ign. sys. seem ok.It never dies out .It just has no spark after running. Please help.
    Thanks Jon Allen"
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,293
    Default Ignition switch? Jeff
    Ignition switch?
    Jeff
  3. #3
    Join Date
    Aug 2008
    Location
    Fairport, NY
    Posts
    1,635
    Default ""It never dies out .It ju
    ""It never dies out .It just has no spark after running."
    Sounds like something in the ignition side doesn't like to be warm (from running) AND work with low voltage (during starting). I'm thinking an electronic, maybe connector issue. You might consider heating up the ignition module area with a hair dryer to operating temperature and then try a start."
Similar Threads
  1. Fogging Crusader 1986 350hp carbed
    By bluedog2 in forum Crusader Marine Engine Forum
    Last Post: 12-31-2009, 01:12 AM
  2. Intermittent surging in 454 crusader
    By ken_o in forum Crusader Marine Engine Forum
    Last Post: 09-01-2009, 03:26 PM
  3. Crusader RPM Loss
    By CaptMikeB in forum Crusader Marine Archive
    Last Post: 09-24-2008, 06:59 PM
  4. Intermittent brief loss of 1or 2 cylinders
    By Bill Wright in forum Johnson Evinrude Outboard Archive
    Last Post: 06-30-2006, 03:56 PM
  5. No Spark on Starboard and weak intermittent spark on Port
    By 543svet in forum Volvo Penta Gas Archive
    Last Post: 06-22-2006, 07:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
