18hp evinrude fastwin
bgharb2
"i have a 60 model 18hp fastwi
"i have a 60 model 18hp fastwin , the gas will not go into the carb , lines are free filter is free , but will not fill carb , any help?"
Do you feel that the primer bu
Do you feel that the primer bulb is full of fuel? I used to have an Attwood fuel hose assembly that was junk compared to the BRP one I now use. It was always very hard (if not impossible) for me to prime the engine with it. I would start there first.
Also check the fuel pickup in the tank to see if it is intact and not sucking air from somewhere or has a plugged inlet filter.
"If you have fuel in the line,
"If you have fuel in the line, up to where it would normally enter the carburetor.... the float needle valve is stuck. The cure would be to remove the carburetor, clean and rebuild it as needed."
If you get it going let me kno
If you get it going let me know what was wrong I am having trouble with my 18 fast twin. thanks
