Req maint on 15 HP Mate
aj4ct
"I am a new owner of a 1.5 HP
"I am a new owner of a 1.5 HP Mate, 1969 model 1902C. Just ordered a manual, but want to try out today. Lower end lubrication spec.s before I start e'r up.."
"Good idea to change the gear
"Good idea to change the gear lube, check it for water at the very least.
Be prepared to renew the water pump impeller unless you know it has been done recently.
Clean/check plug (J6C, 0.030")
Clean out fuel tank (clean filter if there is one, not sure)& make fresh fuel mix 50:1.(TCW3 oil)
Be prepared to clean carb. Instructions for setting the high and low speed needles HERE
Much of THIS ITEMfrom the iBoats forum should be of interest to you."
"Use what is called HiVis 80/9
"Use what is called HiVis 80/90w gearcase oil. Available at any dealership, marine type stores, Wal*Mart, K-Mart, etc."
