Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2009
    Location
    Post Falls, Idaho, kootenal
    Posts
    6
    Default I took the battery out to char
    I took the battery out to charge I put it back in. Now nothing works. no power anywhere not even the trim. Is there a fuse somewhere that I don't know about. I checked the ones on the motor they all look good. Thanks for your help
  2. #2
    goindeep1's Avatar
    goindeep1 Guest
    Default Aloha Bob Does your boat have
    Aloha Bob
    Does your boat have a battery selector switch the one that is for 2 battery hook up. If you do then try to play with the switch turn the knob back and foward to you see any power come on. If this fails then try recleaning the terminals. Let me know what happens and I will look in my trouble shooting in my manual to see what other problems it coulb be. Oh and I know you just charged the battery but try and check it with a voltage tester
  3. #3
    Join Date
    Jul 2009
    Location
    Posts
    6
    Default "thanks for your help it has j
    "thanks for your help it has just one battery the battery is full charge,All fuses on outboard are good. the trim button on the outboard won't work the gas gauge won't work. help lost in Idaho"
  4. #4
    Join Date
    Jul 2009
    Location
    Posts
    6
    Default There is power at the starter
  5. #5
    Join Date
    Jul 2009
    Location
    Posts
    6
    Default I tryed jump start no luck. H
    I tryed jump start no luck. Hear nothing when trying to jump no click nothing.
  6. #6
    Join Date
    Jul 2009
    Location
    Posts
    6
    Default No power at the key. Power at
    No power at the key. Power at the starter.
  7. #7
    goindeep1's Avatar
    goindeep1 Guest
    Default "Aloha Bob Try to check to se
    "Aloha Bob
    Try to check to see if you have power to your GPS,VHF,FISHFINDER ETC and if you do then that will help me help you figure this out. The other is that I see you mention that there is no power at key but power at starter try and trace the wire from the motor up to the ignition to see if there is a loose connection between the the motor and ignition and try to clean the ground terminal on the motor it self. Let me know what happens and I will look in to it more."
  8. #8
    Join Date
    Jul 2009
    Location
    Posts
    6
    Default I replaced all fuses. There wa
    I replaced all fuses. There was a bad 50amp fuse I learn that if they look good they still could be bad. live and learn. Thanks for your help. Gone fishing!!
Similar Threads
  1. Yamaha 115 hp Outboard
    By hoosier19 in forum Yamaha Outboard Archive
    Last Post: 03-15-2009, 12:23 AM
  2. YAMAHA 25 OUTBOARD
    By wild27 in forum Yamaha Outboard Archive
    Last Post: 08-23-2008, 09:53 PM
  3. Yamaha outboard
    By sadhuf in forum Yamaha Outboard Archive
    Last Post: 05-14-2008, 01:35 AM
  4. ID YAMAHA OUTBOARD
    By shadmaster3 in forum Yamaha Outboard Archive
    Last Post: 02-26-2008, 05:31 PM
  5. Yamaha outboard
    By dundee in forum Outboard motors archive 2000-2004
    Last Post: 02-25-2003, 01:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
