Turning the key clicking no start 1990 57L
2geer
Replaced the key ignition swit
Replaced the key ignition switch on the dash - no change. Turning the key back and forth will eventually kick the starter. Thanks in advance for your help.
Could be - I know enough to be
Could be - I know enough to be dangerous on this stuff. What would be the next part to swap downstream of the ignition switch?
dg
"1) go directly to the sta
"1) go directly to the starter , short the yel/red wire to the main battery lug on the starter,this should spin the motor.no, replace starter solenoid
2) locate slave, using a jumper from the battery, touch the small yel/red lead, starter should operate.No, replace slave
3) check ,remove, clean both main battery cable ends where they connect, especiall the neg block one."
"Some of the slave solenoids h
"Some of the slave solenoids have a dedicated ground lead; if the slave doesn't pull in, make sure that lead is clean and tight."
Did a quick check under the co
Did a quick check under the cover this AM. Is the slave solenoid located on top of the engine (left) immediately adjacent the red circuit breaker button?
