Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2009
    Location
    Punta gorda, Fl,
    Posts
    3
    Default was pumping buzzer went off an
    was pumping buzzer went off and started it} later didnt pump out pisser tube changed impeler still does not pump took out thurmastate checked it good flushed water up tube and does not come out but if I flush from top and it does HELP
  2. #2
    Join Date
    Dec 2008
    Location
    cape coral, florida,
    Posts
    172
    Default what did the old impellar look
    what did the old impellar look like? sounds like something is stuck in the pick up tube
  3. #3
    Join Date
    Dec 2008
    Location
    Posts
    172
    Default also look at the water pump ho
    also look at the water pump housing itself check to see if the inside is melted or cracked.
  4. #4
    Join Date
    Jul 2009
    Location
    Punta gorda, Fl,
    Posts
    3
    Default How do I remove water pickup t
    How do I remove water pickup tube pulling and twisting does not seem to be working
  5. #5
    Join Date
    Jul 2009
    Location
    Punta gorda, Fl,
    Posts
    3
    Default It looked ok I found out that
    It looked ok I found out that my neighbor who was helping me ran a drill up the water pickup and it most likely drilled a hole in it and I am not able to remove it
Similar Threads
  1. Pumping oil
    By dnaidee in forum Volvo Penta Diesel
    Last Post: 02-09-2010, 05:02 PM
  2. Water pumping
    By the_beave in forum Mercury Mariner Outboard Archive
    Last Post: 08-01-2009, 06:26 PM
  3. Oil pumping problem
    By Billy Hunt in forum Yamaha Outboard Archive
    Last Post: 10-08-2008, 01:15 AM
  4. 110 not pumping or impeller
    By mkmiller in forum Mercury Mariner Outboard Archive
    Last Post: 08-17-2008, 01:59 PM
  5. Water pumping
    By jrfish in forum Mercury Mariner Outboard Archive
    Last Post: 11-15-2006, 03:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
