"Hello all, first post. I am n
"Hello all, first post. I am new to the boating world and recently picked up a 1996 Bass Tracker with a 25 horse Merc 2stroke on it. I sat recently but it was last year. I thought I had stored it correctly. Fogged the motor and put fuel stabilizer in the tank. Wrapped it up tight to keep water out. This last week I pulled it out and put the motor flusher on it and primed the motor a few times and she coughed a bit and fired right up. It smoked for a few minutes (fogging oil) and the water pump was working well, nice strong stream. Installed the new prop. My buddy and I figured all was well. Went off to the lake, did not put any fresh fuel in the tank. Got on the water and she started right up, idled nice. We took off downhill (15 mph tailwind) and got about three or four hundred feet and she coughed once, then it sputtered and stalled. Started back up and died again. Continued doing this til it refused to start at all. We were in the middle of the lake and seeing as how we were in the middle of the lake, we fished. Well that wind started getting worse and our anchor was slipping, unbeknownst to us. Well, I think we just hoped it would start magically for us. Nope. Wound up using the trolling motor the whole way back up hill, cold and raining and windy. Now on the return trip, our main battery died and we wound up just pulling all electrical off the batteries except for the trolling motor. Made it back to the trailer.
Flash forward to this past weekend, we put the wiring back together but it seems we got the starter wires crossed somehow and had tried the starter in reverse a few times. The wiring is normal now and the motor spins like a champ and with the flusher it has water from cranking from the pump. We drained the tank completely and put in fresh fuel with a good TCW-3 oil and stabilizer and no dice. We pulled the plugs and they look awesome and are definitely getting plenty of fuel, wet. We tried checking for spark and could not find any. We are very experienced car mechanics and can rebuild auto transmission without sweating but we don't know where to start on this. We checked all the fuses we could find and they all are good. The inline fuses on the wiring seemed good as well. Can anyone help me get my outboard running again? I really miss fishing.
Thanks in advance
Motor specs
1996 Mercury 25 Horse 2 stroke (classic I believe)
Serial number 0G288618.
Checking for ohms,
Stator -
Red/Black measured 141 ohms (spec at 100-180)
Blue/Black measured 3.15 ohms (spec at 29-35 X100)
Red/Blue measured 3.01 ohms (spec at 28-34 X100)
Trigger - (Brwn/Wht)/(Brwn/Ylw) .762 ohms (spec at 6.5 - 8.5 X100)
Coils - (positive disconnected)
Upper -
Across terminals .3
Boot to terminal .938
Lower -
Across terminals .3
Boot to terminal .933
I have had suggestions of a bad stator, so I replaced it. Got a good deal on it. Installed that and had no difference. Any ideas as to what it might be?
Thanks for any help you can offer."
Thanks in advance
Motor specs
Checking for ohms,
Stator -
Upper -
Across terminals .3
Lower -
Across terminals .3
