Results 1 to 4 of 4
  1. #1
    Default "I just replaced the water pum
    "I just replaced the water pump on my Yamaha 150hp OX66 and now it won't go in gear, what did I do wrong?"
  2. #2
    Default "I disengaged the linkage and
    "I disengaged the linkage and and the throttle works. I lowered the foot and can turn prop, I raised the foot and can not turn prop or engage from controls."
  3. #3
    Join Date
    Jun 2009
    Location
    Kingsland, Texas, USA
    Posts
    7
    Default After you replaced the impelle
    After you replaced the impeller and as you reassembled did you make sure you lined up and install the small shaft (shifter shaft with splines) in the correct position. I have seem this installed incorrectly in the past. Shaft located in the front section of lower unit on very top section. Also reconnect the small hose that reads water pressure for your speed if you still use it.
  4. #4
    Default "Thanks,after some trouble sho
    "Thanks,after some trouble shooting Idid find that the throttle linkage was misaligned. Lessoned learned"
Similar Threads
  1. 1987 johnson 150hp stalls in gear
    By dawgs in forum Johnson Evinrude Outboard Forum
    Last Post: 07-20-2010, 05:51 PM
  2. 2001 150hp Mercury jumps when in forward gear
    By trophy91 in forum Mercury Mariner Outboard Archive
    Last Post: 09-12-2009, 03:19 PM
  3. 06 Yamaha idles rough bogs down and wonbt run in gear
    By jere in forum Yamaha Outboard Forum
    Last Post: 08-12-2009, 11:36 AM
  4. 1991 Force 150HP wonbt shut down
    By dan_hinman in forum Chrysler Force Outboard Archive
    Last Post: 04-16-2007, 06:11 PM
  5. 1998 evenrude 150hp FICT wonbt start
    By Scott Lewis in forum Johnson Evinrude Outboard Archive
    Last Post: 03-24-2004, 06:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
