PROBLEM WHIT MY WATER PUMP HOUSING
baz69
"I WAS GOING FOR A RIDE WHIT M
"I WAS GOING FOR A RIDE WHIT MY BOAT AND IT STARTED TO HEAT, SO I STOP IT ,CAME BACK HOME AND ALL THE WATER PUMP HOUSING WAS ALL MELTED ,SO WHAT IS THE THING THAT I HAVE TO CHECK ,THANKS STEPHANE"
I had a simular problem last w
I had a simular problem last week. i was check over the boat in the driveway and had it running on muffs I told my son to give it a little bit of throttle and he took it to full throttle. and before i could get it shut down there was smoke comeing from the impeller housing. the housing was melted and cracked when I pulled it off the boat I found that the steel liner inside the housing had twisted and would not let water go into the engine. also check the small hose that comes off the back of the housing and make sure it is not stopped up.
