Results 1 to 2 of 2
  1. #1
    Join Date
    Jun 2009
    Location
    Canada
    Posts
    1
    Default "I have a pontoon boat that I
    "I have a pontoon boat that I can adjust the transom height on. What is the ideal position of the center of the prop in relation to the bottom of the keel? Does anyone know? "
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,131
    Default "Pontoon's can be challeng
    "Pontoon's can be challenging to rig for a couple reasons - there are no "standards", so each mfg makes them a little differently and they kinda display the properties of a semi-displacement hull but they tend to be factory rigged as if they were a planing hull.
    So your best bet is to draw an imaginary line between the lowest point of the pontoons themself at the back of the boat.
    The cavitation plate of the lower unit should be directly in line with that "imaginary" line. That should be your starting point for making fine trim adjustments (so the entire prop should be below the lowest point of the pontoon).
    That will ensure, that if the pods do manage to plane out you won't suck air and fry your powerhead from lack of cooling water."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
Similar Threads
  1. Replies: 8
    Last Post: 12-23-2010, 02:20 AM
  2. PCM 351 Starter on with Key in OFF position
    By boomvang in forum Pleasurecraft Marine PCM Forum
    Last Post: 06-09-2009, 09:34 PM
  3. Converting a 4236 Perkins to Keel Cooling
    By big_h_buck in forum Perkins
    Last Post: 07-24-2008, 06:24 PM
  4. Trim position
    By alexdyer in forum Johnson Evinrude Outboard Archive
    Last Post: 04-29-2007, 07:09 PM
  5. KEEL COOLING A OMC 23
    By CLINT RENARD in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-05-2004, 04:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
