Results 1 to 2 of 2
  1. #1
    Join Date
    Jun 2009
    Peterborough, Ontario, Canada
    Default "I have a little 2.5 hp on a f
    "I have a little 2.5 hp on a freighter canoe. When under power, the steering is very, very stiff, and I see that there are some minor grooves being worn in the motor lower unit where it contacts the teflon ?? bushing. I grease this bushing regularly with lithium grease and have backed off the tension screw almost to zero, but it is almost a two hander to turn the motor under power. At slow speeds there is no problem. Any ideas? Thanks folks."
  2. #2
    Join Date
    Jun 2009
    New Plymouth,Taranaki,New Zealand
    Default "Hi Larry,the force of thrust
    "Hi Larry,the force of thrust must be twisting the motor inside the tube.can u recreate that force with it on the boat on land,to c if it still binds up.may have to remove bushes and renew ,especially the upper one."
Similar Threads
  1. Hard Steering
    By kimmy in forum Johnson Evinrude Outboard Archive
    Last Post: 04-12-2009, 05:57 PM
  2. Hard steering
    By keeleyson in forum Volvo Penta Gas Archive
    Last Post: 05-22-2007, 10:48 AM
  3. Hard steering to right on io
    By Terry Davis in forum Mercruiser Sterndrive Archive
    Last Post: 04-27-2007, 06:36 PM
  4. Hard Steering
    By stormin_n in forum Yamaha Outboard Archive
    Last Post: 02-19-2007, 10:02 PM
  5. Hard steering
    By doug_k in forum Johnson Evinrude Outboard Archive
    Last Post: 06-18-2006, 01:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
