Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2009
    Southend on Sea UK
    Default "hi there ive been browsing th
    "hi there ive been browsing this forum for months and have found some great information from you guys.
    i have a yamaha 90 1987 which i bought about a month ago. When i go out on my local river i have to do 8 knots through about a mile of moorings before i can open the taps. Through the moorings running at 8 knots i think the engine is only fireing on 2 cylinders as when i rev it just a little more the boat launches itself forward and a big boost in power comes out of the engine.(but doesnt rev alot more, just more power). Then after getting through the moorings on the river theres no speed limits so i slowly open the taps and it runs fine after the big boost. After about a minuet the engine just dies and i have to wait a min or two before it will restart.
    if any one could help or anyone has any ideas i would be very greatful
    if u need anymore info ill try my best to explain it in more detail
  2. #2
    Join Date
    Apr 2009
    Greenville, South Carolina, USA
    Default "if it runs at low speed but n
    "if it runs at low speed but not high speed then probably a fuel delivery issue, tank vent, fuel lines, bulb, filters, fuel pump, fresh/clean fuel? carbs clean?...check it out and good luck!"
  3. #3
    Join Date
    Jun 2009
    Southend on Sea UK
    Default "yesturday i found the problem
    "yesturday i found the problem to the high speed fuel delivery, the seal for the fuel filter was nackered so ive changed that and took her out today and she was fine at high speeds absolutly perfect!!!
    but just around 2500rpm, if u just tap the accelorator down a tiny bit more then the boat revs to around 4750 rpm's. its really wierd has any one got any ideas?
    thanks mike"
Similar Threads
  1. 2.2 Mercury 1987 No spark
    By rfinkel in forum Mercury Mariner Outboard Forum
    Last Post: 08-27-2010, 10:24 AM
  2. Yamaha 1987 external fuel tank vent
    By Ron Ritchuk in forum Yamaha Outboard Archive
    Last Post: 06-13-2008, 11:05 PM
  3. 1987 Yamaha 115 V4 no spark
    By pj350 in forum Yamaha Outboard Archive
    Last Post: 07-05-2007, 11:28 PM
  4. 1987 Johnson VRO 140 is not getting any spark or minimal spark to the 3rd cylinder
    By yginesta in forum Johnson Evinrude Outboard Archive
    Last Post: 05-23-2007, 01:30 AM
  5. No Spark In 1987 65TC
    By Randall Varilek in forum Suzuki Outboard Archive
    Last Post: 05-09-2007, 06:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
