Results 1 to 4 of 4
  1. #1
    Default "When running boat at a set sp
    "When running boat at a set speed, speed may drop up to 4 miles and hour then back to set speed. Motor seems to run and sound fine. Any thoughts?"
  2. #2
    Join Date
    Aug 2008
    Location
    Seattle, Washington, USA
    Posts
    36
    Default "Tim, going to need way more i
    "Tim, going to need way more info then that. Does the RPM fluctuate or stay consistent, are you reading this speed from a GPS, fishfinder speed (non-gps paddlewhell) or traditional water tube type speed gauge on your boat? Are you in smooth calm wind lake waters or windy salt tide prone waters? Need more info to help you with this one. - Gerry"
  3. #3
    Default "Calm waters yesterday no wind
    "Calm waters yesterday no winds, I'll check again but think rpms stayed the same, Boat speed from water tube type speed gauge, I know the speed drops and picks up again i can feel it in the boat"
  4. #4
    Join Date
    Aug 2008
    Location
    Posts
    36
    Default "Tim, I would see if you can g
    "Tim, I would see if you can get a portable GPS or some secondary speed measuring device and confirm the speed drop you feel. If your rpms are consistent the whole time and there is no large change in the water current you are transiting then short of some type of intermittent propeller slippage (which should give some indication of rpm increase), I am not sure what the deal might be. This is all assuming there is an actual speed change. Let us know how your next test runs go. Good Luck! - Gerry"
Similar Threads
  1. More speed
    By ozzie in forum Johnson Evinrude Outboard Archive
    Last Post: 08-19-2009, 06:56 AM
  2. 57 GXI engine rpm tach fluctuates wildly
    By coveuser in forum Volvo Penta Gas Archive
    Last Post: 10-21-2008, 12:02 PM
  3. 318 starboard temp guage fluctuates
    By norbie in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 04-11-2008, 04:57 PM
  4. Speed
    By bengo in forum Volvo Penta Gas Archive
    Last Post: 03-11-2008, 11:36 PM
  5. Oil pressure fluctuates
    By Don C. in forum Mercruiser Sterndrive Archive
    Last Post: 10-15-2006, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
