Results 1 to 2 of 2
  1. #1
    Join Date
    Jun 2009
    Location
    Perry, Fl, US
    Posts
    1
    Default "YAMAHA 90ETLH about 85-87 yea
    "YAMAHA 90ETLH about 85-87 year I think, having problems with the motor hard to steer. We have disconnected the steering cable and it is loose and fine. We have greased and put some heat to the base where the grease fitting is located to try and loosen the motor. But it got a little worse. It takes all the muscle you can get to get it to turn. Does anyone have any suggestions as to what the problem could be or any other ideas as to how we might get it to loosen. Thanks"
  2. #2
    Join Date
    Jun 2009
    Location
    Southend on Sea UK
    Posts
    6
    Default if its any consulation mine is
    if its any consulation mine is exactly the same. very smooth and easy to move at low speed but at high speed it takes alot. if you trim it up a bit it does improve a bit.
Similar Threads
  1. hard to turn
    By marke in forum Johnson Evinrude Outboard Forum
    Last Post: 07-30-2010, 02:38 PM
  2. MY Turn Need 350 motor
    By kghost in forum Mercruiser Sterndrive Archive
    Last Post: 06-01-2009, 10:29 AM
  3. Motor will not even turn overstart sometimes
    By cmone42 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-25-2007, 03:03 AM
  4. Motor will not turn off
    By ken d in forum Mercury Mariner Outboard Archive
    Last Post: 05-12-2007, 08:53 PM
  5. Hard Steeringhard to Turn
    By boatman8514 in forum Volvo Penta Gas Archive
    Last Post: 03-27-2007, 08:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
