Adapt an outdrive from a 43lx to a straight 6 merc 165
currenjw
"I have a Bertram 20 with a me
"I have a Bertram 20 with a mercruiser 165 with a bad old outdrive. I've acquired an Alpha 1, gen II outdrive with a 4.3lx engine in bad shape.
Can I hookup the alpha outdrive to the 165 by changing the exaust y with a single?"
what year is the 165hp ? inlin
what year is the 165hp ? inline 6 ?
can I ask what you paid for the v6 and drive ?
replacing the old drive would've cost you about 1295 for a complete unit
"[b]"Can I hookup the alph
""Can I hookup the alpha outdrive to the 165 by changing the exaust y with a single?"
Ayuh,... That's Not the only fitment Issue you're going to run into....
The rear motor mounts are spaced differently,...
The Input shaft on the drive is a Different length...
And,... I'm Sure there are More..."
"alpha 1 Gen II outdrive with
"alpha 1 Gen II outdrive with assoc parts is a nice upgrade, can get up to 210hp(4bbl vortec heads and intake) with basic merc parts, more if you want to do head work.
Only problem is if you have an I drive the transom mount and gimbal housing mount holes are different on the transom."
Thanks for the help.I had boug
Thanks for the help.I had bought a bare hull which had filled in the transom. tapping tells me the job is questionable so I'll rebuild it from the inside.Then look for a well qualified guy to install the outdrive after he reseals it.New pump too.Can you reccommend a guy near Hollywood fl.My mechanic good buddy moved away
and I'v lost touch with the good machine shops.
I seek reliability not speed. Ill flush all hydraulics and
"Your earlier question.... wh
"Your earlier question.... what did I pay?....
I bought a whole boat(19'Monterey) and have removed engine and outdrive etc, Cost$700. Only the begining of the cost."
"not bad, good luck with findi
"not bad, good luck with finding someone down there.. All hobbies and loves come at a price."
